Is this pump a true ddc unit? http://www.pccomponentes.com/ibercool_bomba_laing_ddc_1t.html I know that they are rebrands but a ddc from ek is 70 euros and this one(Spanish company) is 45.
If its a good one,would it be better to run this one and not a d5,which costs 70 euros? 70 euros+30 for an ek top
https://linustechtips.com/topic/521091-legit-ddc-pump/
laing DDC pumps can be good and bad.
great for small footprint and use, bad as the pump will need some airflow to
prevent overheating (add-on heatsink). the less wattage DDC are great for
a CPU loop, just  no multiple blocks. the 18w pump is great for multiple block
builds (CPU/GPU).
review these links for great subject matter:
http://linustechtips.com/main/topic/5435-watercooling-faq-some-basic-qa/
http://linustechtips.com/main/topic/1755-water-cooling-101-a-good-place-for-newbies-to-start/
https://linustechtips.com/topic/521091-legit-ddc-pump/#findComment-6921347
