My First Build [Build Log - The Basic]
Hello there,
I wish you happy and nice new year 2016 full of GPUs and CPUs and amazing Builds!!!  :)
__________________________________________________________________________________________
Okay, so this is my fisrt build i have ever done. I know it is not something amazing, overkill or anything else but still work perfectly for me.
FUTURE
  •  Have my build more colorful --> Black and red build (Paint some components)
  •  Get some "protect" covers for my cabels in
  •  Deal with the "valume" of Powersupplie fan
So, my parts:
C-TECH LADON [36$]
Good looking case, Cheap ATX, mATX, mITX
Cable management, Dust filters, support 7x 120x120mm Fans
post-270889-0-05640400-1451687620_thumb.
AMD Athlon X4 860K Black Edition Kaveri [84$]
Processor Quad-Core, 3.7GHz, 4MB cache, BOX, socket FM2+, 95W
Why this processor? It's cheap, best AMD's performance per dollar
Asus Strix GTX950 [181$]
2GB GDDR5 (6610MHz), NVIDIA GeForce GTX950 (1165MHz), Boost clock 1355MHz, PCIe x16, 128bit, 2x DVI, HDMI, DisplayPort
MSI A78M-E45 V2 [63$]
Actualy, i wasn't 100% sure if this is better than this one ---> MSI A88X-G41 PC Mate: differences --> G41 is an ATX, with "only" 2 RAM slots, less USB 3.0 ports and 12$ more expensive than E45
Kingston 8GB KIT DDR3 1600MHz CL10 HyperX Fury Blue Series [48$]
2x4GB, 1600MHz, CL10 Nice looking, good quality
post-270889-0-21059600-1451687600_thumb.
SilentiumPC Fera 2 HE1224 [28$]
cooler on my processor...becouse everybody know...AMD's Box cooler is trash
Intel 535 120GB SSD bulk [73$]
Read = 540 MB/s
Write = 480MB/s
It's intel  :D
WD Blue 1000GB 64MB cache [61$]
7200 rotation/s
Write = 150MB/s
post-270889-0-50650400-1451687613_thumb.
NOCTUA NF-S12A PWM [20$]
120x120mm
automatic regulation of fans
post-270889-0-24243500-1451687615_thumb.
NOCTUA NF-S12A FLX [20$]
120x120mm
post-270889-0-05690900-1451687617_thumb.
EVGA 500B [61$]
quiet, 80 plus bronze
post-270889-0-25194500-1451687618_thumb.
C-TECH SCORPIA [31$]
Backlight = 7 colours, programmable
706$ - not the best  PC for 700$ Budget but... it is mine idea  ;)
Screens:
post-270889-0-51636600-1451687536_thumb.
post-270889-0-55459100-1451687538_thumb.
post-270889-0-88829400-1451687544_thumb.
Benchmarks/Games stats:
Some stats from games:
GTA V: Max. settings - Around 60FPS
CoD Black Ops III - Max. settings 60-70FPS
The Witcher III - Medium settings 50-60FPS
The Sims 4 - Max. Settings 70-80FPS
3dMark - Firestrike -post-270889-0-71830400-1451689415_thumb.
I want to know what i can change in a future.  :)
https://linustechtips.com/topic/518280-my-first-build-build-log-the-basic/
Looks like a good build!
Insert flamewar on not choosing intel below.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
Not a fan of the case being red and the inside being blue. Inside red would have worked to match the case the noctuas and the copper heat pipes on your heat sink. But im guessing the motherboard made your decision for inside accent colour.
Why do you always die right after I fix you?
my ocd is crying but its performance will make my ocd shut up
Ariana Grande's Leaked Nudes!!!111!11!
Ayyyyyy
Gaming Rig:     CPU:  i5-4690k  Cooler:  H80i  Mobo:  MSI z97 PC MATE  RAM:  16gb Fury White  Storage:  1TB WD + 120gb Fury SSD  GPU:  GTX 970  Case:  NZXT S340  PSU:  NEX 650W  Keyboard:  K65 RGB  Mouse:  Mionix Naos 7000  Headphones:  ATH-M50x  Monitor:  2x VN248h-P + 1x MG248q  Setup Photo:  (To come)
You right... It is becouse of mobo, RAMs and a had Sapphire R7 250X which was also blue. I am not sure if red and black or blue and black
I like the amd box cooler better then the intel one... at least it performs better, and has a metal retention arms then the stupid plastic tab things Intel has that I can never get to go all the way in...
I agree with that. But still is better to buy a new one for both brands.
yes. Unless your on a budget. I would have skiped the cpu cooler and gone for a r9 380x instead of a 950.
Damn. Which company did that? and what is it??
that is so beautiful
well its nzxt, but I think your case copied that that one (its the nzxt phantom)
I did not realize that  -_-
Its fine it wont sound like a jet engine...
