Hello,
I was using my Razer Kraken headset for quite some time. But couple days ago my right headphone stopped working. I was testing it on my: PC, Laptop, Tablet, Phone and non of those worked. I was trying to open the headset but there is no easy way to. Do you know what is reason of my problem and how to solve it ?
https://linustechtips.com/topic/516411-problems-with-razer-kraken-headset/
Sometimes headphones just break. Do you remember bending it accidentally or the 3.5mm cable came unplugged accidentally. If not I would probably return it
:] Sorry for large image
Ariana Grande's Leaked Nudes!!!111!11!
Ayyyyyy
Gaming Rig:     CPU:  i5-4690k  Cooler:  H80i  Mobo:  MSI z97 PC MATE  RAM:  16gb Fury White  Storage:  1TB WD + 120gb Fury SSD  GPU:  GTX 970  Case:  NZXT S340  PSU:  NEX 650W  Keyboard:  K65 RGB  Mouse:  Mionix Naos 7000  Headphones:  ATH-M50x  Monitor:  2x VN248h-P + 1x MG248q  Setup Photo:  (To come)
Most likely it failed due to being cheap junk. That is, the driver has failed or come disconnected. Only way to know is to crack the thing open and take a look at the innards. Assuming the problem is even fixable, you'll need to be able to do some soldering, and possibly a cable replacement if that turns out to have been the point of failure due to short.
I assume that you've already tried the headset with other devices to isolate it as the source of the issue.
Same thing happened to mine.
I'll tell you the same thing I did, PERSONAL EXPERIENCE.
Take then AND SHOVE THEM UP RAZERS CEO'S ASS.
( Over exaggerated lol ) just junk then and go buy a pair of Kingston HyperX Clouds. 10x better quality. Wait... 100000000000x. The Krakens are pure shit.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
