I have an Xbox One and an Elgato HD60 game capture device. I am looking to livestream via twitch using the Elgato software. What specs would you recommend for around $500. I am not against building a PC for it but if I could get the specs in an already made PC for my price, I will go with that.
https://linustechtips.com/topic/516298-need-some-pc-advice/
I don't know a lot about broadcasting software but I have 2 very popular recommendations:
- OBS - Open Broadcaster Software is simple, very easy to use and functional.
- I've heard only good things about XSplit Broadcaster but it costs money.
If they can accept your capture device as a source.
CPU: Pentium G3258 @ 3.2ghz    Motherboard: Gigabyte Z97X-SLI   RAM: 1x 8GB HyperX Fury    GPU: GTS450
HDD: 250GB WD    SSD: 240GB SanDisk Now300   PSU: Old 400W Thing   Monitor: Old Samsung LCD 1680x1050
Keyboard: Perixx PX-1100   Mouse: Perixx MX3000-R   HeadphonesAudioTechnica ATH-M50X BL   Mic: Auna MIC-900BG
https://linustechtips.com/topic/516298-need-some-pc-advice/#findComment-6865798
https://www.youtube.com/results?search_query=500+pc+2015+linus
Linus, Austin Evans, Tek Syndicate are Channels I know good and like but others are good too  :)
https://linustechtips.com/topic/516298-need-some-pc-advice/#findComment-6865810
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($97.89 @ OutletPC)
Motherboard: MSI 970 GAMING ATX AM3+ Motherboard  ($82.98 @ Newegg)
Video Card: XFX Radeon R9 380 2GB Double Dissipation Video Card  ($193.98 @ Newegg)
Case: DIYPC FM08-Blue ATX Mid Tower Case  ($31.98 @ Newegg)
Total: $554.68
Generated by PCPartPicker 2015-12-30 02:30 EST-0500
https://linustechtips.com/topic/516298-need-some-pc-advice/#findComment-6867428
Total: $554.68
You can also get a cheaper gpu to cut down the price
https://linustechtips.com/topic/516298-need-some-pc-advice/#findComment-6868672
