~snip~
Hey there marioleno23,
Can you see the drive in BIOS, Device Manager or Disk Management when you boot from your SSD? Have you tried swapping SATA cables or ports? Can you use it as a secondary drive on another computer?
I would suggest going to Disk Management and see if the drive has a letter assigned to it. Checking the drive's S.M.A.R.T. status with a tool provided by the manufacturer can give you some insights about its health. :) Post back with some test results.
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/516221-hard-drive-problem/#findComment-6869199
