USB-C battery pack?
Is this a good one? I know it has high reviews on Amazon but I wanna see if anyone has experience with this company's products.
http://www.amazon.com/gp/product/B0188DIXX6?keywords=usb%20c%20battery&qid=1451364868&ref_=sr_1_7&sr=8-7
If you have another suggestion for a USB-C battery pack let me know. I don't want/need a gigantic battery and it seems that's the only kind Anker has out right now with USB-C.
https://linustechtips.com/topic/515874-usb-c-battery-pack/
The usb c on that pack is marked as in only. Huh.
https://linustechtips.com/topic/515874-usb-c-battery-pack/#findComment-6861081
Your 5X doesn't support quick charge 2.0 iinm. Save some money from buying QC 2.0 certified powerbank and just get a decent one with at least 5V@2.4A output. Your phone should register it as 'charging rapidly'. And why not get a spare usb type C to type A too. I bought an Anker Powercore 20100 powerbank with (PowerIQ) max output 5V@2.4v and it works ok for my 950 XL, which does actually supports QC 2.0.
https://linustechtips.com/topic/515874-usb-c-battery-pack/#findComment-6861516
