Disable fan LED?
Go to solution Solved by W-L,
As the title indicates, is there any way of disabling a LEDs on fans? (cutting the LED wire?)
I'm buying an exhaust fan for my case, and it's going on the windowed side panel, so I would like it to be clear.
Problem is the only clear fans that look good are with LEDs, but I don't really like them.
Cheers.
Some have a jumper that you can remove but most will require the power leads to the LED to be cut.
Cheers.
https://linustechtips.com/topic/514558-disable-fan-led/
Cheers.
https://linustechtips.com/topic/514558-disable-fan-led/#findComment-6846630
