Hey guys.
My friend has asked me to build him a PC for him to use for flight simulators, all he wants it for is the simulator and nothing else. He's budget is about £400-450. I have no idea if flight simulators need more CPU power or GPU power, and help or builds you can suggest would be great. Thanks
https://linustechtips.com/topic/510471-flight-simulator-build-help/
Yeah FSX sorry, no monitor or peripherals needed sorry
xD
Here you go, if you could get a free OS i could do better.
Motherboard: ASRock Z170M Pro4S Micro ATX LGA1151 Motherboard  (£78.45 @ Amazon UK)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  (£34.07 @ Amazon UK)
Video Card: XFX Radeon R7 360 2GB Core Edition Video Card  (£79.82 @ More Computers)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  (£72.99 @ Amazon UK)
Total: £448.25
Generated by PCPartPicker 2015-12-22 14:08 GMT+0000
Without OS
Video Card: MSI GeForce GTX 960 2GB Video Card  (£154.74 @ Aria PC)
Total: £450.18
Generated by PCPartPicker 2015-12-22 14:10 GMT+0000
Note that the PSU comes with the case itself.
It is not a very good power supply, but will do the job considering that 66% of the wattage will be used on load.
ehh if you dont believe me, i dont care. have fun with 15~ fps o/
Mhmm yes 15 fps.
What are you running on? A cardboard box?
Pentium 4/Athlon XP or better
CPU Speed: 2.4 GHz RAM: 512 MB
OS: Windows XP
Video Card: 256 MB 100% DirectX 9.0c video card (NVIDIA GeForce 6800 or better)
DirectX version: 9.0c
Sound Card: Yes
Free Disk Space: 14 GB DVD-ROM: Yes
Mhmm yes 15 fps.
OS: Windows XP
Sound Card: Yes
edit: i am aware i play this game at high settings with mods.
have you ever played this game?
specs:
cpu: i5 3570
gpu: gtx 660ti KFA 3gb
case: NZXT s340
storage: 1x 1tb hdd 1x 128gb SSD
RAM: 2x4gb hyperX fury black
cpu cooler: cooler master hyper 212 evo
motherboard: ASrock B75 Pro3
keyboard: razer blackwidow stealth
mouse: logitech g502 proteus core
mousepad: steelseries qck+
headset: 3d cloud soundblasters
monitor: benq xl2411z monitor 2: dell u2415
specs:
cpu: i5 3570
case: NZXT s340
Would this work for it?
PCPartPicker part list: http://uk.pcpartpicker.com/p/QqZWgs
CPU: AMD FX-6300 3.5GHz 6-Core Processor  (£78.77 @ CCL Computers)
Motherboard: ASRock 980DE3/U3S3 ATX AM3+ Motherboard  (£49.08 @ Dabs)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1333 Memory  (£34.18 @ Amazon UK)
Storage: Seagate  1TB 3.5" 7200RPM Hybrid Internal Hard Drive  (£51.98 @ Novatech)
Video Card: Asus GeForce GTX 950 2GB Video Card  (£120.00 @ CCL Computers)
Case: Xigmatek Recon ATX Mid Tower Case  (£22.78 @ CCL Computers)
Power Supply: SeaSonic ECO 430W 80+ Bronze Certified Fully-Modular ATX Power Supply  (£34.98 @ Amazon UK)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  (£9.00 @ CCL Computers)
Total: £473.76
Generated by PCPartPicker 2015-12-22 14:21 GMT+0000
specs:
cpu: i5 3570
case: NZXT s340
Your CPU is weaker than the one i suggested in the build single core wise.
If your build can't run FSX, then tell me.
xD
Total: £448.25
Without OS
Total: £450.18
Would this be good?
Total: £473.76
Would this be good?
Total: £473.76
Waiting for "Mr played this game before" to answer you before i throw in my thoughts.
But oh well.
The CPU doesn't fair well single thread wise, which is pretty bad for a game which mainly focuses on a single CPU core.
And AMD CPUs have terrible single core performances to begin with, so not recommended.
I recommend going with a i3 skylake so you can overclock it at a later time, and asrock already released skylake bios overclock updates.
The 6100 is better without overclock in single threaded tasks than the i5-3570, not to mention headroom for overclocks as well.
TL:DR = FX6300 has 14/20 the performance of a i3-6100
