Hello people of the LinusTechTips forum.
My computer has a gtx 660 with a 4790k and 32 gigs of ram. Would be upgrading to say a gt 960 be better than putting two gtx 660s in SLI? Would there be similar performance? Or would the SLI of two 660s be better? Thanks for any help  :)
https://linustechtips.com/topic/509981-double-gpus-for-editing/
I would go get a 960, then if you can afford it later, run it in SLI. I would not SLI a 660. Super bottleneck.
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
https://linustechtips.com/topic/509981-double-gpus-for-editing/#findComment-6800291
The 380 is the best 960 you can buy. Nevermind, for editing.
https://linustechtips.com/topic/509981-double-gpus-for-editing/#findComment-6800295
Depending on the programm i would still choose a 380 because OpenCL usually gives better performance than CUDA. I also haven't heard too much good about Maxwell support in Video Editing.
My Rig: AMD Ryzen 5800x3D | Scythe Fuma 2 | RX6600XT Red Devil | B550M Steel Legend | Fury Renegade 32GB 3600MTs | 980 Pro Gen4 - RAID0 - Kingston A400 480GB x2 RAID1 - Seagate Barracuda 1TB x2 | Fractal Design Integra M 650W | InWin 103 | Mic. - SM57 | Headphones - Sony MDR-1A | Keyboard - Roccat Vulcan 100 AIMO | Mouse - Steelseries Rival 310 | Monitor - Dell S3422DWG
https://linustechtips.com/topic/509981-double-gpus-for-editing/#findComment-6800319
What about GPU acceleration?
Because Vegas is based on OpenCL AMD cards will always give you better performance there because AMD worked a lot to get it implemented nicely. Not sure about after effects, im sure they support AMD cards throught OpenGL, not sure how performance is there though.
https://linustechtips.com/topic/509981-double-gpus-for-editing/#findComment-6800447
Guest
