Hello,
I recently worked on my friend's new computer (new install of W7 Home Premium) and when I run a game (Dota 2 as an example) the FPS is noticeably low even at the very LOWEST settings!
Here is his pc's spec:
CPU: AMD A4-6300 APU with Radeon HD Graphics (Two-core) at 3.7Ghz
GPU: NVIDIA GeForce GTX 750 TI 2GB
Motherboard: Does it matter?
PSU: EVGA 500w
I've updated the graphic drivers as I thought that would be it but there was no difference.
Though Windows Updates are not fully installed yet, but would that affect the performance at all?
What I notice as well is that when I run Dota 2 the CPU is literally running at 100%, even when the game is at the lowest settings.
Is this because the CPU is inadequate? Looking at Youtube videos of the same rig they all seem to be running at normal FPS.
Please help!
Thanks
https://linustechtips.com/topic/509703-games-running-at-low-fps/
which output is the monitor plugged to?
the mobo or GPU?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/509703-games-running-at-low-fps/#findComment-6797228
Hello,
PSU: EVGA 500w
Please help!
Thanks
Strange, is it running any tasks in the background?
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/509703-games-running-at-low-fps/#findComment-6797229
the mobo or GPU?
The monitor is plugged into the GPU
Nope, I've closed all other tasks. Even at idle running Chrome at the moment the CPU is on 50%, sometimes shooting up to 100% for some unknown reason
https://linustechtips.com/topic/509703-games-running-at-low-fps/#findComment-6797237
one question
is that a legit Windows?
https://linustechtips.com/topic/509703-games-running-at-low-fps/#findComment-6797244
Unfortunately not.
there is your problem
https://linustechtips.com/topic/509703-games-running-at-low-fps/#findComment-6797270
How would this affect the usage?
I've done this to my personal PC and I've had no problems since day 1.
I'll be sure to avoid this in the future but I would like to know the reason
I seen non-legit windows riddle with hidden with coin mining virus
which may explain the high CPU load
my Core 2 Duo which is a slower CPu could run Win 8.1/10
https://linustechtips.com/topic/509703-games-running-at-low-fps/#findComment-6797287
Correction: the Windows is a legit ISO from Microsoft but it was activated using an activator...
https://linustechtips.com/topic/509703-games-running-at-low-fps/#findComment-6797309
ah those activator links to the hackers KMS server
it pretty much giving a backdoor link to your PC
https://linustechtips.com/topic/509703-games-running-at-low-fps/#findComment-6797322
Will an anti-virus and anti-malware remove these backdoor links or should I start from scratch?
start from scratch
get proper Windows key
download all the patches and install Malwarebytes and Bit-deffender
https://linustechtips.com/topic/509703-games-running-at-low-fps/#findComment-6797342
start from scratch
WEll get a legit windows and then see if the problem still persists, which I doubt it.
I've now got a legit windows and yes, the problem is still there. 100% on CPU when running Dota 2 at low or high settings
https://linustechtips.com/topic/509703-games-running-at-low-fps/#findComment-6798184
Sorry to say but, more than likely you do have a CPU bottleneck.
What settings do you have set for windows personalization? Try changing the theme to Windows Classic. (it will look like windows 95-2000 but will release a bit of the CPU load)
Go to your advanced system settings and change your visual effects to "Adjust for best performance" then adjust your page file to the maximum allowed.
The only thing we have to fear is... Stupidity...
https://linustechtips.com/topic/509703-games-running-at-low-fps/#findComment-6799131
it must be a cpu bottleneck. but i wouldnt think the 6300 would be that bad.  i used to have a 750ti and could play most things at high settings and be more than playable.   but if your cpu is at 100% then thats your issue.
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/509703-games-running-at-low-fps/#findComment-6799393
