Hello everyone!
I wanted to transfer files from a Mac to a PC no problem, so I inserted my USB drive into the Mac. It was originally formatted to OS X (Journaled). I erased the thumb drive (it didn't have anything on it in the first place) and formatted it as MS-DOS (FAT) in the Mac Disk Utility. It said that it was done, so I copied the files from the Mac to the USB drive. Once it was done, I inserted the thumb drive into my PC and it said that it needed to be formatted. I went into the disk management and it says that the format of the thumb drive is "RAW". Does anyone know what this means?
*NOTE: On the Mac, I also tried formatting the thumb drive in exFAT to see if that would help. Windows still sees it formatted as "RAW" (whatever that means).
Thanks!
Ethan
Current System: CPU: Intel i7 4790K 4.6 GHz @ 1.28 volts | Motherboard: MSI Z97S SLI Krait Edition | RAM: Corsair Vengeance 16GB 1600 MHz + G.Skill Ripjaws 8GB 1866 MHz (Total RAM: 24GB) | Cooling: Corsair H100i | GPU: Zotac GTX 1070 AMP! | Storage: WD Black 1TB + Samsung 960 EVO 500GB + SanDisk 500GB SSD + WD Blue 4TB + Seagate 2TB External + Rosewill 3TB External | PSU: Corsair RM850x | Case: NZXT S340 Elite
Planned Upgrades: No idea
https://linustechtips.com/topic/506873-usb-drive-help/
I can't say with any certainty what is wrong, but I can suggest a potential solution that might work.
  1. Plug in the USB drive into your Windows machine
  2. Format it to NTFS
  3. Plug it into your OSX machine
  4. Format it to ExFat
  5. And now see if it will also read in Windows
Additionally which version of Windows do you have?
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
https://linustechtips.com/topic/506873-usb-drive-help/#findComment-6765120
I am running Win 10 64-bit
https://linustechtips.com/topic/506873-usb-drive-help/#findComment-6765143
OK just wanted to make sure, because versions before Windows 7 needed an update to install the ExFat drivers.  I also use both OSX and Windows and have USB keys formatted in Fat and ExFat without the issue you are facing.
It could be that the USB key is no longer 100% reliable due to wear and tear or damage.  It's hard to say without doing a proper diagnosis.
https://linustechtips.com/topic/506873-usb-drive-help/#findComment-6765174
Thanks for your help, but it didn't work. When I put it into Windows, it just formatted 200 MB of it, not all 16 GB that I wanted. And, I created a single partition on the Mac to see if that would help, but on Windows it just says "A:\ is not accessible - The parameter is incorrect." I've never seen this error before.
https://linustechtips.com/topic/506873-usb-drive-help/#findComment-6765243
Did you format by right clicking on the drive in My Computer or using the Disk Manager in Computer Management?
Also check these links, perhaps one of them can help fix the problem.
http://answers.microsoft.com/en-us/windows/forum/windows_8-hardware/usb-sandisk-8-gb-device-showing-as-200mb-how-do-i/f631df0d-9068-4f2d-820e-a6cbe9b464c3?db=5&auth=1
http://forums.sandisk.com/t5/All-SanDisk-USB-Flash-Drives/16-gb-shows-up-as-200-mb/td-p/187836
http://www.insanelymac.com/forum/topic/279727-a-200mb-efi-system-partition-stuck-on-your-usb-drive-and-cant-get-it-off-read-this/
https://linustechtips.com/topic/506873-usb-drive-help/#findComment-6765290
I just went into "This PC", clicked on the drive, and it said that it needed to be formatted.
https://linustechtips.com/topic/506873-usb-drive-help/#findComment-6765301
This PC is what was once referred to as My Computer in previous versions of Windows.  Try formatting using Disk Manager, perhaps even erasing the partitions it may have.
https://linustechtips.com/topic/506873-usb-drive-help/#findComment-6765317
  • 4 weeks later...
Ok so I figured it out - it was just a bad drive. I got a new one and it worked perfectly. Thanks for the help though! :)
https://linustechtips.com/topic/506873-usb-drive-help/#findComment-6949520
