I am a Architecture Student and also a avid gamer.....iam planning to replace my old pc (HP p7-1030in) and build a new one.
My Budget is abt 1500$ max.......pls recommend me all the hardware specs...it has to be a balance between my work (software mainly like autodesk products, vray renders & lumion)
and also be able to play the spec hungry games.....thanks :D
PS: ​pls recommend the PC case, CPU, GPU, ram, power supply, storage configuration and also the cooling system.
I live in Hyderabad, India so pls guide me with the hardware available over here.
https://linustechtips.com/topic/505880-help-new-pc-spec-recommendation/
Nah, the 5820k is a better all-around choice so no 6700k.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
Well, for work YES for games NOT SO MUCH, it all depends on what he wants.
No, it's a better choice even for gaming. I'm not saying you'll get more FPS, but you'll get a more powerful CPU for basically the same money and it's more than enough for gaming. 2-3 FPS is no difference for a 30% faster CPU
which one offers me more juice for rendering???
5820k is up to 30% faster across all cores.
Gpu - just get a high class one like the gtx 970 or something.
Ram - 2x8gb of whatever you prefer, I like Gskill.
Psu - Go for something modular, like the RM series from corsair or EVGA SuperNOVA lineup.
for the gpu going with 2 gtx 970 in sli offer me better performance?? iam fine with spending a couple of dollars more because having more cuda cores would also help in 3d modelling i guess!!
wat about the ram clock speed....and going 32gb will offer me better performance?
That isnt couple bucks more that is a shit ton. You wont really fit in the 1500 mark. If you want to go over it, just get a gtx 980 Ti, it is enough for everything, ask all the pros, they use a single gtx 980Ti.
