Does freesync work on multiple display setups?
Go to solution Solved by Jahramika,
Yes
If you had multiple freesync displays and the ability to connect them all to one gpu with enough display ports, would it be possible to utilize freesync on all of them or would it be limited to just one?
It sounds stupid reading it back because I understand the tech in theory but I just can't seem to resolve the idea.
CPU: TR3960x enermax 360 AIO Mobo: Aorus Master RAM: 128gb ddr4 trident z royal PSU: Seasonic Prime 1300w GPU: 5700xt, 5500xt, rx590 Case: c700p black edition Display: Asus MG279Q ETC: Living the VM life many accessories as needed Storage: My personal cluster is now over 100tb!
