Gaming Headset Help Please!
Hey, so I am going to buy myself a new headset, but I do not know what to get. I commonly use Skype, and I would like it to be 7.1 and preferably leather ear cups that go over ear. I would be willing to go up to 300 dollars.
Thanks!
with that budget, it is better for you to get a headphone instead of a headset, and get a dedicated mic instead (yes, like the one you saw in studios). because well..... headset doesn't really sounds that good compared to "at-the-same-price-point-headphone" because they spend it more on the mic too.... and please stay away from "gaming" thingy, 7.1 is also run by software*(you can get Razer Synapse if you want to use 7.1 anyways).
There's always the headsets from Sennheiser and Audio-Technica.
I own and use, sorted from newest to oldest: SteelSeries 6Gv2. Microsoft SideWinder X4. Mionix Naos 7000. Zowie EC1 Evo. Microsoft SideWinder X8. Microsoft IntelliMouse Explorer 3.0. Dell U2414H. Samsung P2270H. AKG K273 Pro. Sennheiser HD555. Razer Goliathus Speed Medium. Func 1030 L. Qpad CT Medium.
I used to own: Razer DeathAdder 3G. Razer Krait. IntelliMouse Optical 1.1. SteelSeries QcK.
Thanks!
I think you are much better off buying a quality pair of headphones like others have suggested. You could then buy an aftermarket microphone like the Antlion modmic or a blue snowball that would perform much better than the microphones found on gaming headsets.
But, in case you're dead set on a 7.1 all in one solution. The hyper x cloud 2 is about the only 7.1 gaming headset I'd really recommend.
http://www.amazon.com/HyperX-Cloud-Gaming-Headset-PS4/dp/B00SAYCXWG/ref=sr_1_1?s=pc&ie=UTF8&qid=1449885308&sr=1-1&keywords=hyperx+cloud+2
which are on $300+ club, and you can go with a better headphone and just by an AT2020 USB, and you're doing good ._.
Sennheiser GAME ONE, 180$: http://amzn.com/B00GWU8FTK
Sennheiser GAME ZERO, 280$: http://amzn.com/B00KNPYAEY
Audio-Technica ATH-ADG1, 270$: http://amzn.com/B00H8NS1K8
Heck, the ATH-ADG1 was a direct response from Audio Technica for people who bought their headphones and used a Zalman clipon mic. Linus also says that it's the best gaming headset he's heard: https://www.youtube.com/watch?v=ps6cLom8mC4
And really, a modmic is designed for someone who has really, really expensive headphones. And considering that it costs like 50$, I kind of doubt that you'll easily find something with superior audio quality compared to the ATH-AG1. And let's say you do buy a modmic for 50$. You're now looking at 200$+ headphones, plenty of which will benefit from an amp. And now your total is going to be 400-600$ instead.
