100x100 Vesa Wall mount bracket.
_JohnB330ci
Hello there, I'm moving soon (got another thread going as well) and I'm wanting to wall mount my centre monitor so I can fit my speakers below it, I know I need a Wall Vesa Mount bracket (I do want it to be a wall mount so there is no visible pole) however a lot of the reviews on brackets I find, it says about joints becoming lose or the angle adjusters sagging, so I was wondering if anyone (UK Amazon) has a recommended bracket?
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
