no i am afraid that it wont work becouse the 980 ti needs 1 6pin + 1 8pin x 2 = 4  6+2pin wich youre powersupply has but the 980ti needs at least a 600watts of system power wich you have but youre going to have two and one 980 ti draws 250watts so it is 500 watts just for the craphics cards then i dont know wich system you are going to build but
you only have 250 watts on the rest of the system so it depends wich other components in youre pc are but i suppose pretty high end becouse you are going to have 2 980ti
in it and (often) the more higher end draws more
but you at least have the pluggs thats needed
https://linustechtips.com/topic/499365-v750-problem/#findComment-6714952
