HDD>SSD Cloning Issue
Go to solution Solved by Moistmoose,
FIXED!: The SATA cable i was using for some reason didnt allow it to initialize, so i swapped it out, and did some tests to make sure everything was alright and its good, Im now running on full SSD power!
Hey guys, im looking for someone that could possibly help. Just bought a new SSD so i can clone my original HDD over to it. fairly simple, the problem i have is that when im in Acronis, i can select the source and destination disk just fine, but when it boots into Acronis, the destination disk (My new SSD) doesnt initialize so it cant clone it over. Am i missing something simple here?
https://linustechtips.com/topic/497663-hddssd-cloning-issue/
maybe partition the ssd first
or you might need to change to IDE mode in your bios instead of ahci
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/497663-hddssd-cloning-issue/#findComment-6651514
Ive already partitioned it, so i dont think thats it.
Would switching to IDE mode mess anything up?
My current setup is
1TB HDD (Boot Drive)
2x500GB SSD's in Raidc 0
1TB SSD to replace my boot drive
https://linustechtips.com/topic/497663-hddssd-cloning-issue/#findComment-6651842
My current setup is
the raided ssd's might be the prob..I would maybe unplug them both
and make sure you are using the newest version of acronis trueimage
https://linustechtips.com/topic/497663-hddssd-cloning-issue/#findComment-6651888
alright, i unpluged the Raided SSd's and switched to IDE mode with just the HDD and the 1TB SSD, it refused to boot. so i unplugged the new SSD and it booted. so i switched it back. Im drawing blanks
https://linustechtips.com/topic/497663-hddssd-cloning-issue/#findComment-6652047
wait a min...are you trying to boot to windows?
acronis you usually boot to the usb stick and clone from there
and yes...windows wouldn't boot in ide mode...if windows was installed in ahci mode
https://linustechtips.com/topic/497663-hddssd-cloning-issue/#findComment-6652089
Acronis for me lets me select the drives i want while still on windows, then restarts and reboots into its own OS. Still though any reasons an SSD wouldnt initialize in the BIOS but still be detected in windows?
https://linustechtips.com/topic/497663-hddssd-cloning-issue/#findComment-6652132
not usually
only thing that comes to mind is updating firmware on the drive
https://linustechtips.com/topic/497663-hddssd-cloning-issue/#findComment-6652252
