hello everyone of the linustechtips community i need some small help with some OC im doing. i have an i7 920 the im trying to get my overclock back too 3.5ghz like it was before (which was successful) but for some reason i cant get it above 3.1ghz. i tried different ratios and different BCLK frequencies but it just wont go past it. if anyone can help me with this it will be greatly appreciated
https://linustechtips.com/topic/497297-oc-help/
What are the fail symptoms? Won't make it past POST, BSOD's out (if it does what is the error address), won't pass stress testing.
A screenshot of your BIOS settings would be helpful. FAT32 formatted USB in a MOBO port, press F12 while in the BIOS to save a screen to upload (assuming your board supports that functionality, most do).
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/497297-oc-help/#findComment-6647891
Is this an unlocked processor or are you running some sort of home-brew to make the OC work?
"Not breaking it or making it worse is key."
"Bad choices make good stories."
https://linustechtips.com/topic/497297-oc-help/#findComment-6647896
in the bios i have it set to 3.1ghz but when i actually go into windows and check task manager it says 2.9ghz and so does cinebench r15 it says 2.9 but in speccy it says 3.1 so i dont know which is right or not
i will also try to get pics but right now im using my macbook to use the forums. yes this is an unlocked processor
https://linustechtips.com/topic/497297-oc-help/#findComment-6647909
