DDR4 red LED RAM?
Go to solution Solved by Mohenjo,
Thread necro, sorry, but I found these: https://www.overclockers.co.uk/avexir-core-red-series-8gb-2x4gb-ddr4-pc4-19200c16-2400mhz-dual-channel-kit-avd4uz124001604g-2cir-my-100-ar.html
Are they suitable for use with this:http://uk.pcpartpicker.com/part/asus-motherboard-z170progaming
I'd try to work it out myself but I don't really understand RAM and what CAS timing is and all that. :P
All the timing junk is kinda irrelevant, ram is one of the easiest things to upgrade. The mobo is ddr4 therefore it will work :)
I've seen the Avexir red LED ram, but can only find it at DDR3, which is unfortunate, can anyone point me to a DDR4 LED ram that is not Corsair Platinum, I simply can't see the price in them.
Cheers.
My build : http://uk.pcpartpicker.com/p/Ck8VkL
[spoiler spoiler=Crimson Skyline]  My build: http://uk.pcpartpicker.com/p/Ck8VkL | I5-6600K | Hyper 212 Evo | Asus Z170 Pro Gaming + ROG Front Base | Axevir Core Series Red 2X8 2400 | Sandisk SSD Plus 240 GB | Western Digital 1TB Blue | MSI R9 390 | Corsair 760T | Corsair 850 RMI | Dell U2515H IPS | Hyper X II Cloud Red | Corsair K95 RGB | Logitech G602 |
[spoiler spoiler=Laptop] I7 3232QM | Nvidia GT635M | 17.6" TN | 1TB HD | 6GB RAM
https://linustechtips.com/topic/496847-ddr4-red-led-ram/
Cheers.
Simply said, mod some regular DDR4 to have LEDs.
Someone once said: "Having a rollercoaster on a PC would be epic"
So threw a rollercoaster on my K'nex PC: Project Dragon Khan- K'nex rollercoaster PC build
https://linustechtips.com/topic/496847-ddr4-red-led-ram/#findComment-6643173
Cheers.
http://www.avexir.com/product/corespec-ddr4.html
well, it exists
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/496847-ddr4-red-led-ram/#findComment-6643183
It does, but they don't seem to stock it here in the UK.
https://linustechtips.com/topic/496847-ddr4-red-led-ram/#findComment-6643207
Or in the US, try to contact their support, maybe they will sell it to you directly if you ask hard enough
https://linustechtips.com/topic/496847-ddr4-red-led-ram/#findComment-6643215
https://linustechtips.com/topic/496847-ddr4-red-led-ram/#findComment-6643222
https://linustechtips.com/topic/496847-ddr4-red-led-ram/#findComment-6643227
Thanks for your help!
https://linustechtips.com/topic/496847-ddr4-red-led-ram/#findComment-6643288
