Hi Guys,
Just wanted some thoughts on the Motherboard I should get for the following set up. I am also missing a case. I want to keep the costs of both of these as low as possible. ~ £50 per part.
Link to my set up so far below, not sure how to make them show up in the text box.
http://uk.pcpartpicker.com/p/9NN4cf
Not entirely tech savvy so I have no idea what case will fit the parts selected or what motherboard is compatible.
I also have a BenQ XL2720Z 27inch Monitor if that makes a difference to what motherboard to use.
Thanks in advance.
https://linustechtips.com/topic/496750-missing-parts-advice/
Hi Guys,
Thanks in advance.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  (£142.74 @ Aria PC)
Motherboard: MSI H97 PC MATE ATX LGA1150 Motherboard  (£66.16 @ Dabs)
Storage: Sandisk SSD PLUS 240GB 2.5" Solid State Drive  (£57.88 @ Amazon UK)
Case: NZXT S340 (Black) ATX Mid Tower Case  (£57.99 @ Amazon UK)
Total: £359.75
Generated by PCPartPicker 2015-12-01 11:41 GMT+0000
https://linustechtips.com/topic/496750-missing-parts-advice/#findComment-6642155
https://linustechtips.com/topic/496750-missing-parts-advice/#findComment-6642245
@RaptorCandy
Would this suffice ? Its more around my price mark. Or am I massively reducing quality by dropping this low?
MSI: http://uk.pcpartpicker.com/part/msi-motherboard-b85me45
Not sure what the differences are between H97 Boards and this B85 one?
https://linustechtips.com/topic/496750-missing-parts-advice/#findComment-6642354
@RaptorCandy
http://motherboards.specout.com/compare/3792-3826/MSI-H97-PC-Mate-vs-MSI-B85M-E45
I would go for the MSI H97 PC Mate. It's ATX while the one you mentioned is Micro ATX which doesn't look good in the case in my opinion.
https://linustechtips.com/topic/496750-missing-parts-advice/#findComment-6642363
They all seem to be out of stock =(
https://linustechtips.com/topic/496750-missing-parts-advice/#findComment-6642398
