I was looking around the net for PSUs with nice cables since I'm too lazy to sleeve my own. That and I'm worried I will break something. I came across 2 PSUs which are very highly regarded from what I've seen; the Cooler Master V850 80+Gold and the Seasonic Platinum Series 660W.
Right now I'm leaning more towards the CM PSU as it has more wattage in case I want to expand my system. Oh and these PSUs pretty much peak my budget. So what so you guys think?
https://linustechtips.com/topic/49655-power-supply-with-nice-cables/
The second generation Seasonic XP are base on the KM3 platform just like the Cooler Master V series. Since you can get both the CM v850 and the SS-660XP2 in the same price point, atm, I'd go with the CM. It's a higher output unit, higher quality FDB fan, and it can also achieve platinum efficiency despite being rated as gold. Of course, it's overkill for a dual 760 in SLI, but for the same price (you can get it under $120 after MIR), it's an excellent deal.
The Be Quiet Dark Power Pro 10 is also an excellent premium unit which the 550~750w units are on sale ATM at NCIX US for <$140; however considering how you are focusing on the aesthetics of the cables, it most likely a deal breaker for you considering it's uses multi-color cables.
