Silver Arrow Sb-E Extreme COMPATIBLE problem! Need help please
Hello, guys. I just wonder if the Thermalright Silver Arrow Sb-e Extreme is going to left any space for the MSI lightning 770 to fit in the top pcie 3 slot. I'm using the GA z87x ud3h. I know that other gpu will fit but the lightning 770 has some kind of pump on the back + the back plate as well, so it's wider than regular card. Btw, would you please help me rate this build? I'm going to buy all the parts during the next couple months. Just correct me if I made any mistakes because this is my first build.
i5 4670k Haswell
Asrock z87x Extreme 6
MSI gtx 770 lightning (I'm planing to SLI it)
Thermalright Sb-e Extreme (Is this compatible with that gpu and mobo?)
Corsair hx 850w
Samsung 840 series 256gb
Wb Black 2TB
G.skill Ares 16gb
And Cm Stryker
It's a gaming build along with general computing stuff (movies, browsing,...). I'm also planing to run a dual monitor setting.
Thanks very much for helping me. Sorry for my bad English:D.
Can I just put the gpu on the second pcie 3 slot. Will it run at x16 speed?
Can you? Yes.
Will it run at that speed? I'm not sure but it wouldn't matter anyways the most performance you'll lose will probably be ~2 FPS.
Thanks a lot for helping me. I have one more question. If I do SLI, is there any difference in performance if I put 2 graphic cards in the last 2 pcie3 slots instead of the first 2?
you will see performence difference, because afaik the top 2 slots run at 16x each and the bottom at 8x each. Linus done a video about 8x/16x SLI iin the past.
Take a look:
CPU: Intel i7 4790K @4.8GhZ  CPU Cooler: Be Quiet! Dark Rock Pro 2  Motherboard: Gigabyte Z97 UD3H  GPU: Asus ROG RX 480 8G OC Memory: 32GB Gskill Ares 2400Mhz  Storage: 2x Crucial M4 512GB SSD (raid0)  / 1TB Seagate FireCuda SSHD Case: Phanteks Enthoo Evolv ATX PSU: EVGA SuperNOVA P2 750W  Operating System: Windows 10 Enterprise LTSB (64 bit) Other: NZXT Hue+ LED Controller with 8 LED Strips for desk and PC lighting
Why? It should fit nicely into the build. Just do some research and look how much space there is from the CPU soket to the first PCI slot, then look if half of the SIlverarrow's widht is smaller then that, if so it will be fine
EDIT: look at this picture mounting this way will make compatibility 100% sure, if you dont got ultra high ram... (its some G.Skill Ripjawz in the pic, which got a normal high heatsink)
Klick (it's too large)
