need help with gpu coolers
Solved by grayblizzard,
you should not get this gpu unless you are interested in water cooling or small form factor systems. there are good deals out for better coolers that will get you good performance so i would just save for those if you cant afford them already.
instead just pay $10 more for this:
http://pcpartpicker.com/part/msi-video-card-gtx9704gd5toc
or go EVGA:
