What the title says, this only happens like once a day, everything starts to not respond and it would crash with one of those errors... It's really annoying especially when playing Csgo and I always get banned for it -.-
specs :
CPU - AMD FX 8350
GPU - Asus Strix Nvidia Geforce GTX 960 2gb GDDR5 OC
RAM - Corsair Vengeance 16GB
CPU COOLER - Cooler master Hyper 212 EVO
Motherboard - Asus Sabertooth 990FX R2.0
PSU - Evga Supernova G2 650Watt 80+ gold
Case - NZXT SOURCE 530
Storage - 1tb WD blue
some added fans as well
Is this a BSOD?
If it is, you should follow the standard BSOD posting instructions pinned to the top of the troubleshooting page. This will greatly increase you chances of an answer and or fix! :)
Start with the basics: update drivers, un install any newly installed programs, etc. -- But not before following the BSOD posting instructions that'll help more than anything if it is a bsod.
Thanks!
Chris R.
Is this a BSOD?
the blue screen of death only shows the error name and it would somehow 'fix it' after collecting the data of the error but it is always stuck at 0%, but if it does finish (which is rare) and my pc restarts, it would go into bios error saying that it somehow can't read my hard drive or something like that and if i restart my pc everything's back to normal as if nothing happened.( does not fix it :/)
  • 2 weeks later...
