http://www.newegg.com/Product/Product.aspx?Item=N82E16812423165&cm_re=pwm_molex_splitter-_-12-423-165-_-Product
Your new best friend.
Pulling power straight from the PSU with RPM feedback and RPM control for up to four fans.
i7 6700k // H110i GTX, 4xNoctua 140mm Industrial 3k // Asus Z170 Pro Gaming // 8GB 2400mhz // MSI GTX 970 // Enthoo Pro M
https://linustechtips.com/topic/489957-air-cooling-help/#findComment-6571995
