chrome fails, edge fine
Solved by ElectronicTechnology,
I don't want to delete my whole chrome again and have the trouble of all my bookmarks and such, there has to be another sollution
You can export your bookmarks to your desktop temporarily, then delete chrome, reinstall, and import your bookmarks. The only thing you will have to do is reinstall your extensions, but if you're like me, I don't use too many extensions anyway so this part wouldn't take me too long at all.
