Corsair 380T Compatible CPU Cooler
SalmanJunaid
Hi everyone;
As the topic name implies, i'm looking for a CPU cooler for the Corsair 380T.
I'm considering the Noctua NH-U9S but, to be frank, i'm not sure it will fit in the case. I'd appreciate it if anyone could advise me on whether or not it'll fit.
And since i'm on the topic on my build, my part selection could be found here (http://uk.pcpartpicker.com/p/wjPfwP), I'd really like some opinions.
Thanks All
it should fit with 2.5cm to spare (380T max height is 150mm, U9S is 125mm. the case itself is pretty much intended to fit the H100i (the most powerful CPU cooler you could fit in there).
The Cryorig H7 (145mm tall) should fit in there, and look, and perform better than the U9S as well. theres also Cryorig's direct response to the U9S, the M9i.
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
