Wondering what experienced builders think of my first build. Primarily for gaming and basic school purposes.
Intel i-5 4460
Gigabyte GA-B85-HD3 ATX
HyperX Fury (2x4gb)
WD Blue 1tb
MSI R9 380
Seasonic s12ii 520w
NZXT S340 Black
Most of us will ask you what your budget is. So what is your budget for the build?
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
https://linustechtips.com/topic/486658-thoughts-on-first-build/#findComment-6531172
I suggest using pcpartpicker
[CPU] i5-650 [GPU] MSI GTX 750 OC [RAM] Generic 6GB [MOBO] MS-7613 [HDD] WD Blue 1TB [PSU] Silverstone Strider Essential 500W [Next build Q1 2016 http://de.pcpartpicker.com/user/Presmo/saved/ ]
Please follow your own topics.
https://linustechtips.com/topic/486658-thoughts-on-first-build/#findComment-6531177
Intel i-5 4460
HyperX Fury (2x4gb)
WD Blue 1tb
MSI R9 380
Seasonic s12ii 520w
NZXT S340 Black
Pretty good.
Give me a boost.
https://linustechtips.com/topic/486658-thoughts-on-first-build/#findComment-6531204
looks good.
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/486658-thoughts-on-first-build/#findComment-6533217
