Minecraft has been crashing for a while now, and I would appreciate it if anyone could help. Here is the report. Sorry in advance for the spam on the page.
---- Minecraft Crash Report ----
// On the bright side, I bought you a teddy bear!
Time: 11/15/15 7:04 PM
Description: Ticking memory connection
java.lang.NullPointerException: Ticking memory connection
at com.flansmod.common.driveables.DriveableType.getDriveable(DriveableType.java:544)
at com.flansmod.common.driveables.DriveableData.readFromNBT(DriveableData.java:45)
at com.flansmod.common.driveables.DriveableData.<init>(DriveableData.java:34)
at com.flansmod.common.driveables.ItemVehicle.getData(ItemVehicle.java:159)
at com.flansmod.common.driveables.ItemVehicle.func_77659_a(ItemVehicle.java:136)
at net.minecraft.item.ItemStack.func_77957_a(ItemStack.java:146)
at net.minecraft.server.management.ItemInWorldManager.func_73085_a(ItemInWorldManager.java:316)
at net.minecraft.network.NetHandlerPlayServer.func_147346_a(NetHandlerPlayServer.java:539)
at net.minecraft.network.play.client.C08PacketPlayerBlockPlacement.func_148833_a(SourceFile:60)
at net.minecraft.network.play.client.C08PacketPlayerBlockPlacement.func_148833_a(SourceFile:9)
at net.minecraft.network.NetworkManager.func_74428_b(NetworkManager.java:212)
at net.minecraft.network.NetworkSystem.func_151269_c(NetworkSystem.java:165)
at net.minecraft.server.MinecraftServer.func_71190_q(MinecraftServer.java:659)
at net.minecraft.server.MinecraftServer.func_71217_p(MinecraftServer.java:547)
at net.minecraft.server.integrated.IntegratedServer.func_71217_p(IntegratedServer.java:186)
at net.minecraft.server.MinecraftServer.run(MinecraftServer.java:427)
at net.minecraft.server.MinecraftServer$2.run(MinecraftServer.java:685)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Ticking connection --
Details:
Connection: net.minecraft.network.NetworkManager@404c5765
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.7.10
Operating System: Windows 8.1 (amd64) version 6.3
Java Version: 1.8.0_25, Oracle Corporation
Java VM Version: Java HotSpot 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 560506376 bytes (534 MB) / 1440288768 bytes (1373 MB) up to 2120679424 bytes (2022 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx2G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn256M
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
IntCache: cache: 0, tcache: 0, allocated: 13, tallocated: 95
FML: MCP v9.05 FML v7.10.99.99 Minecraft Forge 10.13.4.1517 Optifine OptiFine_1.7.10_HD_U_C1 16 mods loaded, 16 mods active
States: 'U' = Unloaded 'L' = Loaded 'C' = Constructed 'H' = Pre-initialized 'I' = Initialized 'J' = Post-initialized 'A' = Available 'D' = Disabled 'E' = Errored
UCHIJAAAA mcp{9.05} [Minecraft Coder Pack] (minecraft.jar)
UCHIJAAAA FML{7.10.99.99} [Forge Mod Loader] (forge-1.7.10-10.13.4.1517-1.7.10.jar)
UCHIJAAAA Forge{10.13.4.1517} [Minecraft Forge] (forge-1.7.10-10.13.4.1517-1.7.10.jar)
UCHIJAAAA TooManyItems{1.7.10} [TooManyItems] (minecraft.jar)
UCHIJAAAA OpenModsCore{0.8} [OpenModsCore] (minecraft.jar)
UCHIJAAAA advancedgenetics{1.5.9} [Advanced Genetics] (advancedgenetics-1.7.10-1.5.9.jar)
UCHIJAAAA Backpack{2.0.1} [backpack] (backpack-2.0.1-1.7.x.jar)
UCHIJAAAA BiblioCraft{1.11.0} [biblioCraft] (BiblioCraft[v1.11.0][MC1.7.10].jar)
UCHIJAAAA CarpentersBlocks{3.3.7} [Carpenter's Blocks] (Carpenter's Blocks v3.3.7 - MC 1.7.10.jar)
UCHIJAAAA chisel{2.5.0.43} [Chisel 2] (Chisel2-2.5.0.43.jar)
UCHIJAAAA customnpcs{1.7.10d} [CustomNpcs] (CustomNPCs_1.7.10d.jar)
UCHIJAAAA flansmod{4.10.0} [Flan's Mod] (Flans Mod-1.7.10-4.10.0.jar)
UCHIJAAAA journeymap{@JMVERSION@} [JourneyMap] (journeymap-1.7.10-5.1.0-unlimited.jar)
UCHIJAAAA mcheli{0.10.7} [MC Helicopter] (mcheli)
UCHIJAAAA OpenMods{0.8} [OpenMods] (OpenModsLib-1.7.10-0.8 (1).jar)
UCHIJAAAA OpenBlocks{1.4.4} [OpenBlocks] (OpenBlocks-1.7.10-1.4.4.jar)
OpenModsLib class transformers: [stencil_patches:FINISHED],[movement_callback:FINISHED],[map_gen_fix:FINISHED],[gl_capabilities_hook:FINISHED],[player_render_hook:FINISHED]
Class transformer null safety: all safe
Stencil buffer state: Function set: GL30, pool: internal, bits: 8
Profiler Position: N/A (disabled)
Vec3 Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Player Count: 1 / 8; [EntityPlayerMP['darkguy780'/5, l='beachtown', x=191.79, y=72.00, z=444.51]]
Type: Integrated Server (map_client.txt)
Is Modded: Definitely; Client brand changed to 'fml,forge'
https://linustechtips.com/topic/485721-minecraft-crash-please-help/
Looks like flansmod is complaining, try disabling that and see if it stops crashing.
When does it crash? randomly? when you start the game?
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
Im broke, I cant get Fallout 4. But it crashes whenever I place anything from Flan's mod.
Strange, this Github report claims that issue is fixed in 4.6.0, but you are using 4.10 it looks like.
How many GB of ram do you have, and how much is allocated to Minecraft?
I have 8 Gb of ram and have 2 gb allocated to Minecraft. Ill try switching o 4.6 to see if it goes away.
Give MC 4 GB if you can, though I doubt doing so will solve this problem
I tried reverting to a previous version, but realized some of my Flan's mod assets were for version 4.2. Do you think that is making the mod unstable?
Ideally, the mod is able to update its stuff between versions. I don't know much about Flan's mod or if it is backwards compatible.
Does it crash in a new world too?
Yea, I just tried a new world and it crashes there too. I delete those assets just in case. It still crashes.
