This is my first build so any tips or advice would be greatly appreciated. My budget atm is around $800, but is flexible i dont mind waiting. The PC is mainly meant for gaming and surfing web, I play mostly Heroes of the Storm and other MOBAs and i would like to play them on max settings, aswell as being able to run Skyrim (with mods), Fallout 4, OverWatch, and Witcher 3 in pretty decent graphics if possible with the budget. The only part i will not change is the case i love the case's built in cable managment (bit of ocd when it comes to my cables being everywhere). Currency will be in CAD and I have a local shop memoryexpress.com that i would prefer to get my parts from but if not available i dont mind ordering them online but i do not want used parts.
BUILD
Link:http://ca.pcpartpicker.com/p/CKMFjX
Case:CM Storm Scout 2 $120
Mother Board: MSI 970 GAMING ATX AM3+ Motherboard $130
CPU: AMD FX-6300 3.5GHz 6-Core Processor $130
GPU: MSI Radeon R7 370 2GB Video Card $190
PSU:Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply $65
CPU Cooler:Corsair H80i 77.0 CFM Liquid CPU Cooler $125
RAM:Kingston HyperX FURY 8GB (2 x 4GB) DDR3-1866 Memory $65
OS: Windows 10
For the storage i would like to use my 2tb HD i already bought and a SSD but not a very large one just enough for 1 or 2 games and OS
Total $825
I do also have 12gb of ddr3 ram in my pc at the moment so idk if its worth buying brand new ram or just using the old ones, any suggestions on parts or even a completly different build or even just basic build tips greatly appreciated. Thank you in advance for your help :)
Edit: Forgot to mention i dont need any perephrials i have a monitor, keyboard, mouse, headset :)
https://linustechtips.com/topic/484217-first-build/
Link: http://ca.pcpartpicker.com/p/h9QyhM
Case: NZXT Source 210 White
Motherboard: ASRock Anniversary
Processor: Intel Core i3 4170
CPU cooler: Stock
RAM: Kingston HyperX fury (1x8GB)
GPU: MSI AMD R9 390
PSU: EVGA 500W
OS: https://www.reddit.com/r/microsoftsoftwareswap/comments/3snk1x/h_windows_7_8_81_10_windows_server_office_visio/
https://linustechtips.com/topic/484217-first-build/#findComment-6495124
