So I need help using my headset on my newly built computer
By
Nohemi
in Peripherals
in Peripherals
Solved by myk33,
how do you set it as the device in windows 10?
Control Panel/Sound then look down the list likely says something like Digital Audio just click on it and it will be chosen. Should show the lt blue bars on the right.
2
Tobycj ·
Posted in Laptops and Pre-Built Systems0 -
DommoMotto ·
Posted in Troubleshooting2 -
KapteijnK ·
Posted in Troubleshooting17 -
1
busby_bee_boy ·
Posted in Graphics Cards15 -
AutoCorrectBotLeL ·
Leahh ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From Linus Tech Tips:
The Most Awkward Upgrade…. AMD $5000 Ultimate Tech Upgrade
play_circle_filled
Latest From ShortCircuit:
I’m kind of an iPad hater, but this is MAGICAL. - iPad Pro M4
