So I need help using my headset on my newly built computer
By
Nohemi
in Peripherals
in Peripherals
Solved by myk33,
how do you set it as the device in windows 10?
Control Panel/Sound then look down the list likely says something like Digital Audio just click on it and it will be chosen. Should show the lt blue bars on the right.
Timungus1 ·
3
kerriya ·
Posted in Graphics Cards4 -
woodlandgamer ·
Posted in New Builds and Planning3 -
2
jordanbuilds1 ·
Posted in Graphics Cards2 -
2
play_circle_filled
Latest From Linus Tech Tips:
The Most Awkward Upgrade…. AMD $5000 Ultimate Tech Upgrade
