Hi, I am looking for a low form-factor CPU cooler at a max height of 83mm and need it to be around £10 as in the future i'll be getting a water cooler. Thanks
This is my idea: http://www.amazon.co.uk/gp/product/B003JGMVUE/ref=s9_simh_gw_p147_d0_i1?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=desktop-2&pf_rd_r=0YX26NZ1X133VNP8H0W1&pf_rd_t=36701&pf_rd_p=577047927&pf_rd_i=desktop
CPU: Intel i7-4790k | Cooler: Corsair H110i GT | Motherboard: MSI Z97I AC  | Graphics Card: SAPPHIRE R9 280  | http://uk.pcpartpicker.com/p/pszsdC
http://adamredfern.co.uk
http://rewinded.co.uk
http://yewtreeservices.co.uk/
http://asiat.co.uk/
http://ssstelecom.co.uk
http://hndrx.co.uk/
http://wisemove4u.com/
https://linustechtips.com/topic/482550-cheap-small-cpu-cooler/
That looks solid, although can't you just use the stock intel cooler? If your just upgrading it anyways?
I believe it is under 83mm
I'm ordering a K CPU and will need a cooler as my old stock one is being used, thanks though! :)
http://asiat.co.uk/
http://hndrx.co.uk/
https://linustechtips.com/topic/482550-cheap-small-cpu-cooler/#findComment-6473613
Ahh makes sense :)
Unfortunately, under $10 you don't have too many choices!
But the one you picked looks like it will be just fine
https://linustechtips.com/topic/482550-cheap-small-cpu-cooler/#findComment-6473629
Ahh makes sense :)
Great, thanks :D
http://asiat.co.uk/
http://hndrx.co.uk/
https://linustechtips.com/topic/482550-cheap-small-cpu-cooler/#findComment-6473799
