on pcpartpicker when i click at the top where it says see all completed builds it just freezes and everything on the webpage goes non reactive until i hit the back button.. Any suggestions?
TX10 Build Log: http://linustechtips.com/main/topic/456229-tx10-build-log/
Case: TX10-D   Proccessor: i7-5820k   MotherBoard: Asrockx99 Extreme4   Ram: Crucial Ballistix Sport 16GB (DDR4-2400)   GPU: Asus Strix OC 980ti   Storage: 850pro 500gb, 850pro 500gb, 850pro 256gb, WD black 16tb total, Silicon Power S60 120GB   PSU: Seasonic snow silent 1050   Monitors: Three of Asus VG248QE 144Hz 24.0"
https://linustechtips.com/topic/482237-pcpartpicker-problem/
works for me, try clearing your cache/cookies and restarting yoru browser
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/482237-pcpartpicker-problem/#findComment-6469733
Did both :/
https://linustechtips.com/topic/482237-pcpartpicker-problem/#findComment-6469744
Did both :/
guess they just dont like you then
https://linustechtips.com/topic/482237-pcpartpicker-problem/#findComment-6469749
ikr it sucks :(
https://linustechtips.com/topic/482237-pcpartpicker-problem/#findComment-6469756
Try a different browser
eg if you have Chrome, install and try Firefox, if you have Firefox, install and try Chrome.
I have both, since some sites don't work with certain browsers
If you use internet explorer then what are you even doing.
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/482237-pcpartpicker-problem/#findComment-6475533
I was using chrome.. tried with firefox and it worked.. UGH!! WHY CHROME WHY?
https://linustechtips.com/topic/482237-pcpartpicker-problem/#findComment-6476707
