Hello,
I was benchmarking my laptop earlyer today, but I had some issues with both the CPU and GPU benchmark.
CPU: i7-4720HQ
GPU: GTX 960m
My CPU has a score of 519 cb. Each time it gets a score of just above 500. In the ranking there is a CPU, an i7-3720QM, which scores 590 cb. When I compare those on cpuboss.com I can see that the 4720hq gets a higher overall score. That was also what I'd expect since it is almost the same processor, but a newer generation. In Cinebench is scores significantly lower though. 519 for the 4th gen, and 590 for the 3rd gen. I have almost no other processes running. If I do not run the benchmark the cpu gets used for about 2%. Is this result normal?
The second problem is with the OpenGL benchmark.
On both my laptop and Desktop (with a 770) it doesn't use the whole gpu. It uses about 30-40% with a spike in the beginning of 50%. On my laptop I get a score of 50.13fps, and on my desktop 99.75 fps. Someone I know with a GTX 960 (desktop 960) has a score of 118 fps. In the rnaking in cinebench itself it also shows the score of a 650m, with 52.75 fps. So my 960m has a lower score than the 650m. Is this also normal? Or is there something wrong?
https://linustechtips.com/topic/481850-cinebench-problems/
