im partial to asus myself i would go with this one, slightly cheaper
http://pcpartpicker.com/part/asus-motherboard-z97a
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/481355-samsung-950-pro/#findComment-6456815
Hello guys,
I just got a Samsung SSD from my girlfriend and the problem is that I have a Z87 motherboard atm. What Z97 motherboard do you guys recommend? I was thinking about the MSI Z97 Gaming 5.
Instead of buying a new motherboard because of one SSD you could also buy a M.2 to PCI-e adapter card.
That way you can put the M.2 SSD on the adapter card and plug it into a PCI-e 4x slot, just like a graphics card.
Something like this:
6422_05_addonics_adm2px4_pcie_3_0_to_m_2
But make sure your current Z87 board supports NVMe.
https://linustechtips.com/topic/481355-samsung-950-pro/#findComment-6456826
That's also an option. But I can't find any (trusted) shops in the Netherlands that sell them at the moment. Selling my current GD65 motherboard won't be a problem, because my friend is willing to buy it if I plan to buy a new one.
Does an adapter works on the Z87 chipset? And the speed isn't reduced?
https://linustechtips.com/topic/481355-samsung-950-pro/#findComment-6456836
The speed is the exact same, cause all it does is to extent the M.2 connectors to the PCI-e slot.
Yes, that works on all boards that support your M.2 SSD. So you would have to make sure that your current Z87 supports NVMe, because you're using a 950 Evo, which is a NVMe drive.
If it doesn't you should be able to find a BIOS update for it.
I was able to find a few adapters on Ebay.NL
http://www.ebay.nl/itm/2-Port-NGFF-M-2-B-M-Key-SSD-to-PCI-E-PCI-Express-4X-Adapter-Converter-Card-/181908971995?hash=item2a5a9ea1db:g:7BkAAOSwaNBUeuto
http://www.ebay.nl/itm/M-2-PCI-e-SSD-to-PCI-e-and-M-2-SATA-SSD-to-SATA-III-Converter-/291287403286?hash=item43d2150b16:g:5sgAAOSwKIpWEp27
The last one can also convert to SATA, but that will reduce speeds.
Edit: The other one can do that, too :P
https://linustechtips.com/topic/481355-samsung-950-pro/#findComment-6456906
Thanks for helping. Appreciate it. I think its faster to buy a new mobo since my friend is willing to buy it right now for around €130. You think the Z97-Gaming 5 is a good one? I just can't wait to use my 950 Pro SSD, since I use a HDD still.
https://linustechtips.com/topic/481355-samsung-950-pro/#findComment-6457070
MSI does not have BIOS update for Z87 mobo to use NVMe. You will need Z97 or newer to use the 950 Pro.
https://linustechtips.com/topic/481355-samsung-950-pro/#findComment-6457098
MSIs Z97 Gaming 5 is a good choice.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/481355-samsung-950-pro/#findComment-6457107
Thanks both, I will order the MSI Gaming 5 now. Everyone thanks for helping.
No problem, buddy.
https://linustechtips.com/topic/481355-samsung-950-pro/#findComment-6457225
They have support for NVMe, but it isn't possible to boot from a NVMe device.
http://www.pcper.com/news/General-Tech/Intel-SSD-750-Series-PCIe-Compatibility-Tested
https://linustechtips.com/topic/481355-samsung-950-pro/#findComment-6457279
Thanks for correction. I read the press release MSI will support "9" chipset. That is H97, Z97 and X99 for NVMe. Also I went to MSI BIOS download section. Didn't see any mention of NVMe in Z87 GD65 Gaming mobo.
I make mistake sometime. :P
https://linustechtips.com/topic/481355-samsung-950-pro/#findComment-6457310
No problem. Everyone does mistakes :P
It wasn't your fault.
Ah, but you can boot from it when you have a Z97 right?
Yes, you can.
https://linustechtips.com/topic/481355-samsung-950-pro/#findComment-6457905
