Hello,
I'm going to college next year and will be studying networking/IT systems and possible 3d design/CAD modeling. So, I need a new PC because my laptop simply won't suffice. My budget is around $500 USD, I'm allowing wiggle room because I also need a mouse and keyboard. I've listed the guts of my planned build below (with case, optical disk drive, mouse, and other parts it comes to $530 usd). I'm not a major gamer but I do like to play gtaV. I'll be using windows 7/10(I also use linux with no unfair bias) but I'm not including it in the budget. Suggestions?
MoBo-> Gigabyte FM2+/FM2 AMD A78
APU-> A10-6800k 4.1GHz quadcore (Radeon HD integrated)
Gpu-> r7 240 2gb
1 Tb sata II HDD
2x 8Gb ram
2x 1Gb
750 watt psu
https://linustechtips.com/topic/479137-build-for-college/
Please use pcpartpicker next time. I would get this instead
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($172.89 @ OutletPC)
Motherboard: Gigabyte GA-B85M-DS3H-A Micro ATX LGA1150 Motherboard ($49.89 @ OutletPC)
Memory: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory ($34.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($44.89 @ OutletPC)
Video Card: XFX Radeon R7 260X 2GB Core Edition Video Card ($115.98 @ Newegg)
Case: Corsair 100R ATX Mid Tower Case ($37.99 @ Micro Center)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($42.99 @ NCIX US)
Total: $499.62
Generated by PCPartPicker 2015-11-04 18:12 EST-0500
You don't need a 750W psu for that kind of build anyway, and what do you mean by RAM to dedicate to the GPU?
https://linustechtips.com/topic/479137-build-for-college/#findComment-6425129
Hello,
I'm going to college next year and will be studying networking/IT systems and possible 3d design/CAD modeling. So, I need a new PC because my laptop simply won't suffice. My budget is around $500 USD, I'm allowing wiggle room because I also need a mouse and keyboard. I've listed the guts of my planned build below (with case, optical disk drive, mouse, and other parts it comes to $530 usd). Any suggestions? I'll be using windows 7/10(I also use linux with no unfair bias) but I'm not including it in the budget.
Gpu-> r7 240 2gb
1 Tb sata II HDD
2x 8Gb ram
2x 1Gb ram to dedicate to GPU
750 watt psu
If you're taking what I bolded, you are going to need an an SSD.  Trust me, I'm taking that program right now.  The recommended requirements for my program include a quad core that supports virtual machines, 16GB of RAM, a 128GB SSD and a 1TB HDD.  And boy do you need the SSD.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/479137-build-for-college/#findComment-6425165
Total: $499.62
He is talking about RAM for the APU. I don't think he knows that it shares system memory. You don't need separate RAM for it.
i7 4790k | GTX 970 | 16GB
That's all you need to know. It's a beast.
https://linustechtips.com/topic/479137-build-for-college/#findComment-6425171
as a tiny APU based alternative:
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor  ($119.99 @ SuperBiiz)
CPU Cooler: CRYORIG C1 65.0 CFM CPU Cooler  ($62.00 @ Newegg)
Motherboard: Gigabyte GA-F2A88XN-WIFI Mini ITX FM2+ Motherboard  ($87.99 @ SuperBiiz)
Total: $522.35
Generated by PCPartPicker 2015-11-04 18:22 EST-0500
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/479137-build-for-college/#findComment-6425224
Memory: Team Elite Plus 8GB (2 x 4GB) DDR3-1600 Memory  ($34.99 @ Newegg)
Video Card: PowerColor Radeon R9 380 2GB PCS+ Video Card  ($144.99 @ Newegg)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($53.99 @ SuperBiiz)
Total: $531.63
Generated by PCPartPicker 2015-11-04 18:24 EST-0500
If I'm way out of the budget tell me
This is a signature.
https://linustechtips.com/topic/479137-build-for-college/#findComment-6425237
My power need was around 500 watt, I've read that a 40-60% overage is ideal. Plus if I upgrade I'll most likely need more power. Also, I've heard negative things about i5 compared to similarly priced amd processors. Thanks for the feedback though, I'll look into that site. 550 usd is my max including mouse and keyboard.
https://linustechtips.com/topic/479137-build-for-college/#findComment-6425245
what have you heard? an i5 will absolutely wreck an AMD chip in single core performance. Amds cpus have a 32nm process thats pretty outdated.
https://linustechtips.com/topic/479137-build-for-college/#findComment-6425287
only problem is that you can't really get all of that in a system under $500 unless you go without a GPU.
Actually I tried it and you can buuut:
https://linustechtips.com/topic/479137-build-for-college/#findComment-6425291
The i5 is better on CPU side than any APU, the reason A10s reach that price is because they've a nice iGPU
https://linustechtips.com/topic/479137-build-for-college/#findComment-6425303
Yeah unfortunately.  And my program requires these specs in a laptop.  The one sold at the bookstore is the cheapest one and it's a G751JT from Asus.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
https://linustechtips.com/topic/479137-build-for-college/#findComment-6426295
i5s are better no matter what you are doing, but i guess fx-6300 isn't horrible... amd is like taking 2010 technology and then giving steroids imo. i don't see a point
I was referring to the FX-8000 series. But, from other discussions I've heard that it depends on the purpose of the PC. Such as for gaming (multi thread) and 3D modeling such as Autodesk, the FX would be better...weaker cores, but more cores that add up to be more powerful.
https://linustechtips.com/topic/479137-build-for-college/#findComment-6432558
