Boot Device LED on in BIOS
Go to solution Solved by Fuzz_Ball,
So in the middle of building my first pc and i've installed windows. When I boot into the bios the boot LED turns red and stays that way. But then when I boot into windows it turns off. So is it an error or a problem or is it okay?
Yeh. It is just a light saying that you are in bios. My Mobo does the same, when I go into the bios
Fire Tail: CPU - Intel 7700k. MOBO - MSI M5 Gaming Z270
RAM - G.Skill RipJaws V 2x8GB (16GB). GPU - MSI 1070 Gaming X
____________________________________________________________________________
Editing Rig: CPU - AMD Ryzen 3900x with NZTX Krackenx240. MOBO - MSI ACE MEG Z570
RAM - G.Skill Trident Z 32GB (16GBx2) 3200hz. GPU - MSI Gaming Trio 2070 Super
