I'm trying to find out about getting a new battery for an inspiron 3542. The type is a XCMRD 14.8 volts. On the dell website, the battery costs over a 100 dollars but I found this site that sells it for 40 dollars but it doesn't mention compatibility for my specific computer. Is there a catch? Will it work?
http://www.uspartsdirect.com/original-dell-inspiron-17-5748-laptop-battery-xcmrd-40-wh-li-ion-14-8-v-4cells-p-191920.html?gclid=Cj0KEQiAsNyxBRDBuKrMhsbt3vwBEiQAdRgPslPuNC24pAcaFQYkgoXs8anU6WVhIOeb_yDT129_YVsaAjQU8P8HAQ
https://linustechtips.com/topic/478048-dell-battery-compatibility/
-SNIP-
If it has the same type of format and layout it will work as long as the voltages are the same and the Wh (watt hour) is the same or higher than the original. Only thing is sometimes those third party batteries might not use very high quality Li-ion or Li-po cells in them.
Amazon also seems to have the product your looking at:
http://www.amazon.com/Genuine-Dell-Battery-XCMRD-Li-ion/dp/B00GPBONSS
Can I put a higher wattage battery? I would like to try to get extra hours of use.
You can install a higher Wh (watt hour)  or mAh (miliamp hour) which is the size or capacity of the battery.
To covert the Wh to mAh:
mAh= Wh/voltage*1000
The unit with the 40Wh is somewhere around 2700mAh.
