https://linustechtips.com/topic/476371-graphic-card-fan-problem/#findComment-6383970
Yes i plugd the 8 pins correct in the graphic card
no the cables that go in to power the cpu by the motherboard heatsink if there not plugged in correctly it can cause whats happening to happen
https://linustechtips.com/topic/476371-graphic-card-fan-problem/#findComment-6387530
