Hi,
I'm looking for a mini pc powerful enough to run windows 10 without stutter or lag between the os and it needs to be powerful enough to last a good few years.
I am looking at these  http://www.amazon.co.uk/Gigabyte-Brix-BXBT-1900-Ultra-Compact/dp/B00MOEMZMQ/ref=pd_cp_147_4?ie=UTF8&refRID=0S82Y46V0V1H4R2P0Y4T&dpID=41YcFDVIXpL&dpSrc=sims&preST=_AC_UL70_SR70%2C70_ , http://www.amazon.co.uk/Intel-DN2820FYKH-Barebone-Graphics-Bluetooth-x/dp/B00HVKLSVC/ref=sr_1_5?ie=UTF8&qid=1446115452&sr=8-5&keywords=zotac+pico   but I need it to have support for a 3.5 inch drive. Any recommendations would be greatly appreciated. Also around the budget of £100 - £140.
Thanks
CPU: Intel i7-4790k | Cooler: Corsair H110i GT | Motherboard: MSI Z97I AC  | Graphics Card: SAPPHIRE R9 280  | http://uk.pcpartpicker.com/p/pszsdC
http://adamredfern.co.uk
http://rewinded.co.uk
http://yewtreeservices.co.uk/
http://asiat.co.uk/
http://ssstelecom.co.uk
http://hndrx.co.uk/
http://wisemove4u.com/
https://linustechtips.com/topic/475629-mini-pc-barebones-kit/
Why do you want them to have 3.5" HDDs?
They are physically shorter than a 3.5" HDD.
As I have recently purchased a 3.5inch hdd for my old pc but if they dont make them with 3.5 inch drive support can you recommend a good mini pc?
http://asiat.co.uk/
http://hndrx.co.uk/
https://linustechtips.com/topic/475629-mini-pc-barebones-kit/#findComment-6373730
I would get an SSD and replace the HDD.
Another alternative is a mITX motherboard and case and you can use your HDD.
https://linustechtips.com/topic/475629-mini-pc-barebones-kit/#findComment-6373752
Okay thanks for the advice :)
http://asiat.co.uk/
http://hndrx.co.uk/
https://linustechtips.com/topic/475629-mini-pc-barebones-kit/#findComment-6373765
