Hey guys!
I'm looking for a proper program to do serious planning of my future build in. I've been thinking about using SketchUp to model all of my ideas into a case or whatever. But I was woundoring if there's something better / easier or if I should just stick with SketchUp ?
I'll be using it for planning at case modding, watercooling and the like.
Everyone have a cool signature. I don't, so I thought I would write something.
- Cool right?
https://linustechtips.com/topic/47562-program-for-planning-out-a-build/
microsoft paint
msi z97m gaming - i5 4690k @4.4ghz 1.2V corsair h110 powercolor r9 290x pcs+ - 8GB corsair vengeance dual channel @2133mhz - thermaltake smart power se 730watts - intel 530 series 240GB ssd seagate 1tb 7200rpm - corsiar obsidian 350D - 2x enermax tb silence 140mm - logitech x-530 - sony mdr xb600 - medion 24'' 1080P cm storm quickfire tk white edition with cherry mx red cheap but awesome mouse #GloriousPaintMasterRace
sketchup is good for the price, i.e free. but i use solidworks, if your a student its significantly reduced in price but if you are doing a one off project use sketchtup.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
