why???im not questioning your knowledge I just want to know the reason...and also could you suggest a good cpu cooler for the i7-6700k also?
scratch that I thought it had more room go with ref as it will pull air from the back of the card and not be choked from the side
how much do you want to spend on the cooler
i dont know yet...may give me suggestions and ill check on the prices....anyway if reference is better what are the safest temps?
what gpu?
980ti to be exact..maybe you could recommend a good itx case also..but I really love the design of phanteks
I love the phanteks too
if you want an alternative look at the 202 and the SG series
