Does it return an error or something, like "cannot find file location"?
Check to see if OBS is already runnning in Task Manager. If it is, end the process and try again.
._.
AMD A8-5500•••ASUS GTX 660•••MSI MS-7778 Mobo•••2x4GB DDR3 RAM•••CoolerMaster v550 Semi-Modular PSU•••1.5TB HDD•256GB Samsung 850 Evo SSD•••Optical Drive•••Phanteks Enthoo Pro
https://linustechtips.com/topic/472757-obs-not-opening/#findComment-6337322
didn't work
Could you explain exactly what happens when you say it doesn't open?
Do you click on it, and it crashes right when you open it? Could you check to see if anything related to OBS happens in task manager when you try to open it?
._.
https://linustechtips.com/topic/472757-obs-not-opening/#findComment-6337415
I click on it and nothing happens. OBS is a background process
https://linustechtips.com/topic/472757-obs-not-opening/#findComment-6337435
Nothing happens if you end the background process and launch it again?
Then the only other thing that I can think of is reinstalling it.
._.
https://linustechtips.com/topic/472757-obs-not-opening/#findComment-6337514
