Hi,
Im nearing the end of my build and am stuck thinking of one thing since the start..
I have have just ordered my second 360 rad, both rads will be push/pull, which means 12 fans (vardar 3000rpm) 1 rear fan + 1 bottom fan (corsair AF)
How/where do i connect 14 top of the market fans and how do i control them? My rads will probably block access to my 5.25 bays (i will be mod'ing case just to squeeze them in) I dont have a problem with a good looking external fan controller on my desk
Thanks
https://linustechtips.com/topic/472554-wiringconectingcontrolling-fans/
Hi,
Thanks
I assume they are the 4 pin PWM versions, for those you can use two of theses swiftech PWM splitters but it will become a group controlled unit.
http://www.amazon.com/Swiftech-8-Way-Splitter-Power-Connector/dp/B00IF6R4C8
