Sorry if this is the wrong section.
I want to buy an optical drive for my computer. I want it to be able to read and write Blu Ray DVDs as well as regular DVDs. Does this describe all Blu Ray readers or are there some that only work with Blu Ray or can't read/write regular DVDs?
Are there any recommendations for a good deal on an optical drive? Also, is there any difference between a nice one and a less expensive one?
https://linustechtips.com/topic/470913-optical-drive-recommendation/
Get the cheapest blue Ray drive.
They can all do dvds
For most people, I would generally recommend you don't get an optical drive at all. However, if you have a lot of optical media that you use regularly, then I suppose it's worth it.
Just find the cheapest one that supports Blu-Ray read and write and buy it.
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
