Hi,  I'm looking to add white lighting to my c70 but have no idea what length of strip to get! either 12 or 30cm. I don't want the inside of the case to be blindingly bright, just looking for enough light to see the components. Included some pics, any input would be great, thanks.
https://linustechtips.com/topic/47084-bitfenix-alchemy-led-length/
I would go for the 30cm and tuck it under the lip of the side panel.
Where were you planning on putting the strip?
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
I have the 20cm version and it's pretty bright.
12 is plenty, I got 30 and it's a bit bright for my taste, check the pictures in my Sig, mines the C70  as well. You should mod that window, the vent things are so ick.
Case: NZXT H440 | CPU: i5 4670K @ 4.5 GHz | GPU: MSI 970, Kraken G10 | Mobo: ASRock Z97 Extreme3 | Cooler: H100i | PSU: Corsair AX750 w/ Sleeved Cables | Display: 3xBenQ RL2455M | Fans: 5xNoctua NF-F12, 1xBitFenix Spectre |
12 it is then! you could always put black tape over some of the LED's? Modding the window is on my list of things to do, along with, getting the gpu cable extensions, painting the cd drive black, and
the front
the front
I should still stealth my drive, inside and out. Maybe that'll be a weekend project for me. I might try to dim the LEDs indeed, 30 is super strong haha
12 is good for 1 side. grab 30 then provide even lighting. dim them but equal lighting looks nice :D
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
