So....this is my 1st time doin watercooling .hehe .Bought myself a XSPC Raystorm 750 RS240 ... And i've met a problem .
========  .I've noticed once i insert the tubings into the barb fiting . It is almost impossible to get it out . How do you disconnect the tubing from the fittngs (Barbed ) ? I really need you peep's help , NOOB here.LOL
One of my '' Smart '' way to disconect the tubing  :
My pc :
https://linustechtips.com/topic/46651-help-needed-barbs-and-loops/
You have to twist it off slowly, just make sure not to pull on the block or radiators. Hold those down while twisting and pulling.
A scalpel is a good way to get it off if you are in a rush. Just cut along the fitting and it should slip off.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
