use for this build
Gaming & Recording
(Screen resolution, FPS, game settings)
1080p, max, ultra.
budget
$1200
In what country are you purchasing your parts?
US
potential build
http://pcpartpicker.com/p/4xPJrH
additional details
Is the psu overboard? (I've used this case before, keyboard and mouse is fine for me.) Is the cpu overkill?
Let me know if I need to change anything, cheers.  B)
https://linustechtips.com/topic/462856-build-help/
use for this build
Gaming & Recording
1080p, max, ultra.
budget
$1200
US
potential build
additional details
Do you live near a MicroCenter?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/462856-build-help/#findComment-6211536
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler  ($101.19 @ Amazon)
Motherboard: Gigabyte GA-Z97X-SLI ATX LGA1150 Motherboard  ($104.89 @ OutletPC)
Storage: Samsung 850 EVO 250GB M.2-2280 Solid State Drive  ($107.99 @ Adorama)
Video Card: Gigabyte Radeon R9 390 8GB SOC Video Card  ($309.99 @ Amazon)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($104.99 @ NCIX US)
Total: $1321.90
Generated by PCPartPicker 2015-10-07 00:07 EDT-0400
Living near a MicroCenter will save you about 60-80 USD on this if you pick up some parts in-store.
https://linustechtips.com/topic/462856-build-help/#findComment-6211562
Total: $1321.90
I would love to water cool, but i dont know anything about it. And i REALLY dont want to use water. Is there an alternative thing for water that i cant put in?
https://linustechtips.com/topic/462856-build-help/#findComment-6211720
AiO (All in One) liquid coolers are prefilled and there's no risk for leakage. They also perform much better than air cooling and you'll be able to overclock like a beast. There is no risk and you shouldn't be worried.
https://linustechtips.com/topic/462856-build-help/#findComment-6211732
Thats all what I needed to hear, thank you very much.
https://linustechtips.com/topic/462856-build-help/#findComment-6211733
No problem!
PS: If I solved your problem, you can mark my answer as solved so others may find this thread and get their answers more easily.  ;)
https://linustechtips.com/topic/462856-build-help/#findComment-6211745
$1250, no SSD though.  I would recommend one.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($379.95 @ SuperBiiz)
CPU Cooler: be quiet! Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($59.99 @ NCIX US)
Motherboard: Gigabyte GA-X99-UD3P (rev. 1.0) ATX LGA2011-3 Motherboard  ($153.98 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (4 x 4GB) DDR4-2400 Memory  ($109.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.99 @ SuperBiiz)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card  ($274.99 @ Newegg)
Case: Phanteks Enthoo Pro M ATX Mid Tower Case  ($84.99 @ Amazon)  <<Very flexible pick.  Mostly picked for fun.
Power Supply: Antec HCG M 850W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($69.99 @ Newegg)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($29.99 @ Directron)
Total: $1209.86
Generated by PCPartPicker 2015-10-07 00:58 EDT-0400
https://linustechtips.com/topic/462856-build-help/#findComment-6211803
Since we got the water cooler, how much could I push it to? 4.5 ghz?
Eh... More around 4.6-4.7. Expect great things from this rig.
https://linustechtips.com/topic/462856-build-help/#findComment-6211883
