hey guys just had a weird issue with my pc,
i just started the new payday 2 game after downloading it and within ten minutes my screen flashed and then my graphics card was stuck at 405mhz and 0.917volts. which my standard is 940mhz at 1.18volts
then i decided to restart to try and resolve my issue which was the presented with a plan blue screen with no writing on and crashed. i then pulled my card from the rig and tried on board all is fine. the weird thing is it blue screens once its fully loaded up and loaded up start-up items. im currently in the process of re-installing windows to see if i accidentally clicked the clock speed beyond 950mhz which is when it starts crashing my system.
any ideas would be great, i have sent my problem to asus to see if i get a reply but probably not.
system spec:
sabertooth z77
i7 3770k
8gb corsqir veangance 1866
samsung 830 ssd 128gb os installed
gtx 560 asus direct cuii oc edition
corsair cx600
if it is the end of my graphics card looks like i have an excuse to upgrade to the 760 earlier than planned.
CPU: i7 3770k 4.5ghz M/Board: Sabertooth Z77 GPU: Asus Gtx 560 Direct CUii OC RAM: 2x4gb Corsair Veangance PSU: Corsair CX600 Cooler: Custome Water Loop With Gentle typhoon 1850rpm fan, Single 120mm Rad, XSPC Raystorm CPU Block
https://linustechtips.com/topic/45889-graphics-card-problem-causing-bosd-win7/
If you have the latest drivers, donwgrade them.
i cant because i blue screen upon start-up
Start Windows in safe mode.
There's a time and place for everything! But not now. - Professor Oak
i7 2600K 4.3GHz  -  GTX 1060 3GB  - ASUS P8Z68-V - 16GB DDR3-1600 CL9 - EIZO 1080p 120Hz VA
Intel Skulltrail: 2x Core 2 Quad QX9775 - Intel D5400XS - 16GB FB DDR2-800 CL5 Quad Channel
EVGA SR-2 Classified - 2x Xeon X5675 4.2GHz - 24GB DDR3-1830 C10 Triple Channel
Intel Skulltrail #2: 2x Xeon E5472  - Intel D5400XS - 16GB FB DDR2-667 CL5 Quad Channel
Take your your graphics card then...
Take out the gpu, downgrade the drivers and plug the gpu back in
Nzxt Phantom 410 - I5 4670k stock - 7950 vapor x @ 1000mhz/1250mhz - Msi Z87 G45 - 8gb Corsair Vengeance pro 1600mhz - TX650 - Benq XL2420t - Blackwidow Ultimate 2013 - Deathadder 2013
i blue screen on safe mode aswell and the drivers are not showing after removing the card
Why would you reinstall windows to see if you clicked the wrong clock? Remove the card, boot from the onboard graphics, temporarily remove the overclocking software if it won't run without a card plugged in, and boot with the card again.
When you use software to overclock, the card does not remember the speeds you set, they are set upon boot by the software, if you remove the software or disable it, whatever clocks you set will not be applied.
Where are you looking for the drivers?
Look in control panel add/remove programs to see if it appears under Nvidia, if it does, uninstall everything green, the run driversweeper, check the Nvidia boxes, clean. Restart the PC then shut it down, then put the card in and boot, if it can boot, windows will then attempt to re install whatever driver you had last installed, then install the latest one over the top of that by just running the installer.
This would be a good start.
too late already installed windows 7 and all seems fine will know in future thanks everyone
thing was my laptop was at mt grans and my phone was dead on battery so i panicked thinking it was my graphics card honestly i think it was to to do with lucid mvp 2.0 which was causing problems with some games.
Glad it's fixed! Like you said, maybe next time come to the forum before taking drastic measures! :D
ok after installing windows and upgrading to win8 as i had a code i have been issued the same problem after my 3rd restart which caused a bsod boot cycle which windows recovered from after a restore system image to when i installed teamspeak which was the first thing i installed. i made sure not to download the beta graphics drivers but looks like thats not the issue now, and i have no clue to what it could be
What does the BSOD say? Most times it will say on the text display which driver has caused the crash.
nothing just blank
all is good the now but my second display is very dull
